don't pull a stuck rig via hitch-ball |
Post Reply ![]() |
Author | |
alabamatoy ![]() Admin Group ![]() I dont work here anymore... Joined: 16 February 2004 Location: Signal Mountain Status: Offline Points: 9330 |
![]() ![]() ![]() ![]() ![]() Posted: 29 July 2022 at 11:42am |
I have always heard of this being a dangerous possibility, but havent seen it in reality. This fellow apparently tried to pull a stuck truck out of a mudhole by putting a snatch strap onto the hitch ball of the stuck truck then yanking it with his truck. This broke the hitch on the stuck truck, and the stored energy in the stretched strap sent the broken hitch through his windshield and into his face, which killed him. |
BRC Life Member |
98TJ ![]() RCRC Club Member ![]() ![]() Joined: 10 May 2005 Location: Maysville, Madison County Status: Offline Points: 8141 |
I've pulled a bunch of stuff using the hitch ball just like they say not to and never had a problem and never seen anyone have a problem. But I guess I won't do it again.
I watched a couple of videos on this topic a few days ago. Both happened to be Australian. They talked about one incident where the ball didn't break, the ball mount broke. It had been exposed to saltwater for many years and the metal was half eaten up. The other was them destructive testing hitch balls by putting a strap on the and then putting a lot of slack in the strap and running wfo to the end of the strap and breaking the hitch ball bolt. Every one I saw appeared to be a lite rated hitch ball with maybe a 3/4" bolt and likely chinese junk. Most of my hitch balls are 10,000 lb rated with 1-1/4" bolts (IIRC). Anyway , probably not a good idea and I will do something different next time unless I'm pulling something real lite. |
After looking at the photo of the failed dropped ball mount; what manufacturer would build a 15" dropped ball mount with a hollow tube to go in the receiver? That should have been solid steel square bar. That is a gross design failure even if they rated it for extremely lite use. That has to be so chinese junk right there. Somebody gonna get sued if their even still in business.
RL-RRC ![]() Admin Group ![]() ![]() Forum Curator Joined: 19 April 2006 Location: Kirkland,TN Status: Offline Points: 1000096 |
Sad thing is they had the tools to do it a lot better. Should have pulled the hitch and put the strap loop in the receiver and installed the hitch pin.
96 Lexus lx450
85 Toyota Truggy built by Don 02 Jeep WJ Chance favors the prepared! |
NOT4HWY ![]() RCRC Club & Business Member ![]() ![]() Joined: 16 February 2004 Location: Harvest, AL Status: Offline Points: 1438 |
Saw a video many years ago where a winch cable snapped and the recoil cut a bystander in half.
Club member since 1992, Club President 1995-1999 Trail rig:S-Blazer,Rockwells,507 Caddy,T-400,203/205, Tow-rig: '23 F350 4x4
Post Reply ![]() |
Tweet
Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
