86 4Runner Sun Roof Glass |
Post Reply |
Author | ||
Toydawg
RCRC Club Visitor Joined: 20 June 2006 Location: United States Status: Offline Points: 953 |
Post Options
Thanks(0)
Posted: 26 July 2021 at 11:28am |
I lost the sunroof in my 86 4Runner when I trailered it to MS a couple of weeks ago. Literally just blew out, I had no windows open or anything, apparently the air passing over the top just sucked it right off the truck. Anybody know where I could find one, or a suitable replacement that will fill up the hole in the roof? Did I mention that I HATE sunroofs? Thanks
1984 Toyota pickup, locked 5.29s, dual cases, Longfields, 22R with low range cam and header.
98TJ
RCRC Club Member RCRC Club Treasurer Joined: 10 May 2005 Location: Maysville, Madison County Status: Offline Points: 8393 |
Post Options
Thanks(0)
bpr
RCRC Club Member Joined: 02 October 2008 Location: Madison, Al Status: Offline Points: 173 |
Post Options
Thanks(0)
another option is fab a piece and weld it in
2018 JL Rubicon Stock
83K10
RCRC Club & Business Member Joined: 17 February 2004 Location: Huntsville, AL Status: Offline Points: 3174 |
Post Options
Thanks(0)
Good luck. I've been casually looking for one for several years.
Toydawg
Post Options
Thanks(0)
I thought so, was hoping you had found a solution. I saw the $600 one on eBay, really don't want to spend that kind of money on a piece of glass. I like the 'weld it up' idea, but my bud who could do that and make it look factory is no longer with us. Might try a piece of Lexan...
alabamatoy
Admin Group I dont work here anymore... Joined: 16 February 2004 Location: Signal Mountain Status: Offline Points: 9369 |
Post Options
Thanks(0)
You need to sell me the 4Runner. This will solve your problem.
BRC Life Member |
83K10
Post Options
Thanks(0)
Maybe I should just start machining them out of lexan. I need to look close at mine. I can't remember if they are curved or not. I bet there's quite a bit of demand for them.
98TJ
Post Options
Thanks(0)
98TJ
Post Options
Thanks(0)
Toydawg
Post Options
Thanks(0)
It's in MS now. Had I known it was going to shed its Sun Roof at Cullman you might have had an opportunity for purchase...
Edited by Toydawg - 28 July 2021 at 6:48am |
83K10
Post Options
Thanks(0)
I have a blodgett commercial oven that should be large enough to heat them. Hrm....
Toydawg
Post Options
Thanks(0)
I volunteer to provide a test bed for your prototype efforts.
bpr
Post Options
Thanks(0)
if you don't care if it ever opens or it looks factory: cut lexan to fit, use brackets or stops on underside and then fiberglass the top. Shouldn't leak and you could finish and paint top side edges to make it look ok. You would still have light through lexan
Toydawg
Post Options
Thanks(0)
I like this idea, but I don't look forward to the fiberglass piece. I have very limited experience with fiberglass, and the people I know who have used it said it is a pain to work with.
alabamatoy
Post Options
Thanks(0)
I have already made one trip w/ the trailer to Vicksburg this year, another one to get a 4Runner is not intimidating.
BRC Life Member |
Post Reply | |
Tweet
Forum Jump | Forum Permissions You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
