Traveling Jeeper Needing Some Advice |
Post Reply |
Author | |
FishingTails
Newbie Joined: 11 November 2019 Status: Offline Points: 3 |
Post Options
Thanks(0)
Posted: 11 November 2019 at 8:59pm |
Hello Fellow Jeepers, I happen to be passing through Red Bay, AL on my way home to Florida when my Jeep started having a problem I have experienced before. My dashboard starts to light up starting with the Anti-skid (ABS), blinking sway bar alarm, flicking check engine, brake light, even all the transmission indicators are lighting up as if all gears are selected. I had this before when I discovered a bad wiring connection with one my ABS sensors, which caused a short in the computer lighting everything up. Add driving in the rain and chaos ensues. I went to the Jeep dealer in Tupelo and they literally said that I need over $8K of repairs the computer was reporting such as catalyst failure, ABS vacuum pump failures, O2 sensor failures upstream and downstream, Sway bar replacement, etc. I actually tried to explain that this has happen before and it was probably a short generating false positives to the computer moudule. He proceed to tell me no that I actually just experienced over 10 different failure all of a sudden out of the blue, simultaneously. Needless to say, I thanked him for his help and walked away with an oil change and a proactive spark plug replacement for over $500. I am looking for a recommendation for Jeep repair shop between Red Bay and Huntsville that a) actually understands the complexity of a pretty customized Jeep and how it works and b) is someone I can trust to tell me what is really going on here. My experience traveling the country is that jeeper clubs are an invaluable source. If anyone ever needs some recommendations for Orlando, FL, Danbury, CT, & Moab, UT, I am your jeeper. |
2012 Jeep Wrangler Rubicon Unlimited
98TJ
RCRC Club Member RCRC Club Treasurer Joined: 10 May 2005 Location: Maysville, Madison County Status: Online Points: 8391 |
Post Options
Thanks(0)
Give Danny at Rocket City Offroad in Huntsville a call.
Sales: 256-883-1131 call or Text Alternate: 256-837-7277 call or Text |
FishingTails
Post Options
Thanks(0)
Much appreciated 98TJ!
Post Reply | |
Tweet
Forum Jump | Forum Permissions You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
