Forum Home Forum Home > Classified Ads > Wanted!
  New Posts New Posts RSS Feed - toyota V6 Diffs
toyota V6 Diffs
Message Reverse Sort Order
Toydawg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toydawg Quote  Post ReplyReply Direct Link To This Post Topic: toyota V6 Diffs
    Posted: 02 April 2017 at 6:41am
I was thinking about running the 4.56s in my '99 Tacoma, so the 7.5" diff/gears would have to be from that generation.  I know the newer generation gears in the front diffs are reverse cut, so I doubt the early IFS 7.5" gears would work in the newer cases.
1984 Toyota pickup, locked 5.29s, dual cases, Longfields, 22R with low range cam and header.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 83K10 Quote  Post ReplyReply Direct Link To This Post Posted: 01 April 2017 at 7:58am
I don't have a matching 7.5 but I have a 7.5 out of a different truck. I'll have to check the ratio. I think its a 4.10 but I don't remember for sure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toydawg Quote  Post ReplyReply Direct Link To This Post Posted: 31 March 2017 at 5:01pm
Marc,
     I have some V6 carriers and a case if you can use them.  I also have a 8" high pinion carrier (uses the V6 side bearings, but 4 cylinder locker) if that helps as well.
John,
    You don't have the 7.5 third that matches those 4.56 gears do you?
jarmumd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jarmumd Quote  Post ReplyReply Direct Link To This Post Posted: 31 March 2017 at 10:15am
Nah, I bought new 5.29 gears, just need the carrier, not the gears or the housing.  If the internals weren't torn up, I'd see about having you machine a new end cap.
1984 4runner
Post Options Post Options   Thanks (0) Thanks(0)   Quote 83K10 Quote  Post ReplyReply Direct Link To This Post Posted: 31 March 2017 at 7:22am
Mark,
What ratio ring and pinion do you need? Reason I ask is I have a V6 4.56 gear set that I pulled out last week to go to 5.29s. If they'll work for you, you can have them.
John
Post Options Post Options   Thanks (0) Thanks(0)   Quote jarmumd Quote  Post ReplyReply Direct Link To This Post Posted: 30 March 2017 at 9:41pm
Yea, not a big deal but one of the end caps were cracked.  this resulted in the internal gears chewing up, and likely was the cause of the ring and pinion failing.  possibly the end cap was over torqued?
wasnt going to bug you about it, no way you would have known.  thinking i may go lunchbox in an open diff now.  Figured I would ask to see if people had diff centers just laying around.
1984 4runner
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toydawg Quote  Post ReplyReply Direct Link To This Post Posted: 30 March 2017 at 4:11pm
I have some V6 carriers, is there a problem with the True Trac?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jarmumd Quote  Post ReplyReply Direct Link To This Post Posted: 30 March 2017 at 10:20am
Looking for a toyota v6 diff.  Specifically the differential (don't need a housing).  Open is fine.  A broken true trac that I can swap parts from is preferred!
1984 4runner
Forum Software by Web Wiz Forums® version 11.06
Copyright ©2001-2016 Web Wiz Ltd.
This page was generated in 0.047 seconds.
