JK Lower Control Arm Skids |
Post Reply |
Author | |
83K10
RCRC Club & Business Member Joined: 17 February 2004 Location: Huntsville, AL Status: Offline Points: 3178 |
Post Options
Thanks(0)
Posted: 29 June 2016 at 5:51am |
BlackBird
RCRC Club Member Joined: 11 July 2014 Location: NW Huntsville Status: Offline Points: 573 |
Post Options
Thanks(0)
I need this. How much for fronts with install? Do you unbolt the control arms to avoid heat getting to the bushing or does it not matter? One of my axle ears has a small bend so it would be good to get that straightened also.
Michael Crandall
Monrovia Volunteer FF/Driver Mine - 2024 Ram 2500 Rebel Hers - 2023 Jeep GC 4xE Trailhawk |
83K10
Post Options
Thanks(0)
$95 out the door for the fronts only with install. I did not unbolt the control arms as I'm not getting that much heat into them doing this. No issues with them melting or anything of that nature. I did weld them in steps with some cool off time in between to avoid excessive heat into those parts. If you decided you wanted all 4 it would be $145 out the door.
BlackBird
Post Options
Thanks(0)
one thing to note is that a lot of the bigger aftermarket players put a slot in the fronts to accommodate greasable joints. Maybe that can just be an option for you if folks want it.
Michael Crandall
BlackBird
Post Options
Thanks(0)
finally got the fronts done last Friday and it looks great. Should toughen things up down there.
Michael Crandall
gumataotaom
RCRC Club Member Joined: 15 February 2014 Location: United States Status: Offline Points: 205 |
Post Options
Thanks(0)
I might want some of those too John. And other JK skid stuff if you are manufacturing them
Jeep (not schoolbus) with scrapes underneath from following Toyotas
Post Reply | |
Tweet
Forum Jump | Forum Permissions You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
